Truck Dies Intermittently
Old Apr 14, 2013 | 11:27 PM
sammy340's Avatar
Gents,
Please help me diagnose an issue that has got me stumped.
My truck has a problem where it intermittently dies, and I have to restart the engine. This can happen at idle, or when I'm driving. It is just like someone shuts the key off. Truck sometime starts right back up, other times will crank for awhile, but has always eventually started up again. I've done the following to try and solve the issue:
-Replacement of VP44 Injection Pump;
-Fuel Filter replacement (18 PSI consistently post fuel filter);
-Changed the fuel system relay in the fuse box;
-Reset the APPS.
The only things I can think of that are left is:
-Bad ground somewhere;
-Crankshaft postion sensor;
-Camshaft postion sensor;
-ECM.
Truck is a 1998.5 24V standard. Any help is greatly appreciated.
Thanks,
Jeff
Old Apr 14, 2013 | 11:59 PM
Dieselbuilder's Avatar
Any chance of borrowing or have someone run a scanner when you drive around to see what happens when it dies?
Old Apr 20, 2013 | 07:03 PM
sammy340's Avatar
No codes are being thrown when the truck dies.......any other ideas would be appreciated.
Thanks guys,
Jeff
Old Apr 20, 2013 | 09:12 PM
SIXSLUG's Avatar
ignition switch, bad battery cables, loose/damaged ECM connection...
vintovka
Apr 30, 2012 12:38 PM
90 power ram
Oct 6, 2011 08:04 PM
mmwinefeldt
Apr 29, 2008 09:27 AM
03qclb5spd
Jun 14, 2006 10:44 AM
bws
Nov 27, 2005 03:18 PM
