Transmission slipping
Old Jun 10, 2010 | 01:13 PM
jon5's Avatar
I have a '01 3500 dually and when I turn left, the tranny slips. It does not do it going straight or turning right. I have changed the fluid, filter and adjusted the bands and it did not help. Any ideas?
Old Jun 10, 2010 | 03:00 PM
j-fox's Avatar
Is it full of fluid?
Old Jun 10, 2010 | 09:28 PM
dkenny's Avatar
sounds more like differential problem than a transmission problem.
how would the tranny know if you're turning left or right?
just a thought
-dkenny
Old Jun 11, 2010 | 07:55 AM
jon5's Avatar
Well, I originally put in 4 qts. of fluid after the change. I just added 1 more qt. for a total of 5 and slippage is gone. I would have never though 1 qt. would have mattered so much.
Old Jun 13, 2010 | 09:52 AM
Fred Swanson's Avatar
If you just did the pan, try around 6 qts. Check your fluid level.
Old Jun 13, 2010 | 03:37 PM
got_soot's Avatar
Soot For Brains!
what did the fluid level say when you only put 4qts in..also did you check this with the engine running or off..
Old Jun 13, 2010 | 09:43 PM
nickg's Avatar
mine has a stock pan and takes almost 7 liters when changing tranny oil, as mentioned above, if you have a stock tranny, fluid level MUST be checked in neutral, it cannot be checked in park!!!
andrewsurfdude
Jul 18, 2004 06:53 PM
herzog
May 23, 2004 02:22 AM
moneyman
Jan 15, 2003 10:41 AM
doomgaze
Jan 14, 2003 10:09 PM
jonesr2
Oct 12, 2002 04:49 PM
