How to stop slipping transmission?
Old Jan 13, 2003 | 06:27 PM
doomgaze's Avatar
How can I stop/keep from happening/fix/prevent etc the transmission from slipping?<br><br>Is it possible to prevent further damage or am I pretty much on a one way path to a new tranny?
Old Jan 13, 2003 | 07:15 PM
95ramtough's Avatar
Re:How to stop slipping transmission?
Have you done a full tranny service, changed fluid, filter and adjusted bands?
Old Jan 13, 2003 | 11:14 PM
doomgaze's Avatar
I had a full tranny service done when they replaced my leaking cooler lines about 11,000 miles ago.
Old Jan 14, 2003 | 05:44 PM
BigBlue's Avatar
Reduce the power. You could try maybe increasing the line pressure on it. Call Bill K. at DTT and ask him. If it were me, I'd start saving for a new tranny.
Old Jan 14, 2003 | 10:00 PM
ProspectorTim's Avatar
Check your fluid *again*!<br><br>Sometimes after a fluid change, what looks right is actually a quart short. Top it off, see if it works better.<br><br>You could also drop the pan and adjust the bands. You will lose some fluid, but that will also give you a chance to see what the old fluid looks &amp; smells like and check the pan for sediment. If the fluid is dirty or burned, get a new filter and drain out as much as possible. Fresh fluid and a band adjustment might buy you more-than-a-little-bit of time.
Old Jan 14, 2003 | 10:09 PM
Marine's Avatar
Veteran: Marine Corp
With the +4 ATF, it is hard to tell that it is worn. Some of these trans have a short life span because of the sloppy tolerances they are constructed with- They leak internally. If you do not pull a lot, it is doubtful your bands need adjusting to that extreme. If you do the bands, make sure you have a very accuratetorque wrench in inch/pounds. Call Bill K. if any questions.<br><br>Mike
Dusty Ratcliff
14
Nov 28, 2006 09:26 AM
slivertruck
25
Nov 8, 2006 08:35 PM
royta
Nov 6, 2006 08:19 AM
moneyman
Jan 15, 2003 10:41 AM
jonesr2
Oct 12, 2002 04:49 PM
