transmission problems
Old Jan 21, 2011 | 09:35 PM
dj.oneil's Avatar
i have a 2000 dodge it has 250 thousand miles on it i have always changed all the fluid before it is due this morning i went out to leave for work let it worm up and left and the only way it will shift out of first gear is to let of the throttle i am getting ready to change the tranny filter in it tomorrow is there anything else i need to change or look for when i do this thanks for ant help
Old Jan 23, 2011 | 11:10 PM
R.T.D.H.S.P.'s Avatar
throttle valve cable may be out of adjustment. Also, it may be the governor pressure sensor. Search both for explanation. There is plenty of info on the forum.
Old Jan 24, 2011 | 02:23 AM
dj.oneil's Avatar
thanks for the info the trany filter didnt work i will try that thanks
Old Jan 24, 2011 | 02:37 PM
oldblues's Avatar
hi
adjust your front band !
prob loose !
Old Jan 25, 2011 | 06:49 PM
dj.oneil's Avatar
ok i will try that does anyone know the torque specks on it
Old Jan 25, 2011 | 07:05 PM
blacksmokebro's Avatar
Front band is 72 in-lb back off 2 turns..
Rear band is 72 in-lb back off 3 turns...
Make sure you are using an IN-LB torque wrench and not a FT-lb torque wrench..
The front band locknut is 30 FT-lb and the rear is 25 FT-lbs
Old Jan 25, 2011 | 07:29 PM
dj.oneil's Avatar
thanks i will give that a try tomorrow
Old Jan 30, 2011 | 11:08 PM
dj.oneil's Avatar
none of this has helped a buddy told me it could be the tps has anyone heard of that causing the problem
Old Feb 15, 2011 | 04:00 AM
dj.oneil's Avatar
can anyone give me a part number or tell me where i can get the governor pressure sensor at none of the part stores can find one around here thanks
kellio
19
Mar 26, 2021 03:12 AM
Dauntless
15
Aug 30, 2016 08:37 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
JARHEAD
Jun 26, 2004 01:44 PM
baldeagle
Sep 30, 2003 08:09 PM
