Transmission Problems!!!!
Old May 21, 2009 | 12:58 PM
jrv15's Avatar
i have a 99 dually 24V
PROBLEM 1. everytime i start out from a stop it acts like it doesnt want to shift from 1st gear. if i run it hard it really doesnt want to shift. if i take off slow it shifts much better.
PROBLEM 2. when i start out cold, or if i sit at a light for a minute, when i start to go it feels like i am locked into overdrive. the rpms come up good but the truck doesnt go anywhere for 5 seconds then it like kicks in and starts to go.
Old May 21, 2009 | 01:02 PM
nasty01cummims's Avatar
kick down cable....maybe? Wish i could be more help to ya
Old May 22, 2009 | 12:51 AM
Dinner's Avatar
First problem sounds like a faulty Governor Solenoid in the Valve Body. Accelerate like you would normally (somewhat hard I guess you could say), let off of the go pedal and see if the transmission shifts into 2nd. Then continue on driving like normal (Im assuming).
I'm not exactly sure on the 2nd problem, others will chime in about it though.
Old May 22, 2009 | 01:57 AM
WHISTLINTURBO's Avatar
have you checked your tranny fluid level? How old is the fluid and filter? I like to start with the obvious first myself
Old May 22, 2009 | 05:37 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Welcome to the site.
Something else to check....
I had the Speed Sensor on the tailshaft housing go out, causing a late 1st to
2nd shift issue, a couple of years ago.
I think the part was only ~$30 and was easy to change from under the truck.
On cold starts, I've found that letting the truck run for around 30 seconds with your foot on the brake in neutral
will help get the fluid circulating in the auto tranny quicker.
(The stock Dodge tranny doesn't circulate the ATF while in park.
Your drain-back valve might be bad allowing the fluid to leak back out of the converter.
No big deal if you just allow the ATF to get circulating before driving off)
If it's doing it while sitting at a light, check the fluid level (engine running, parking brake on, in Neutural)
Old May 22, 2009 | 09:20 AM
RowJ's Avatar
Originally Posted by WHISTLINTURBO
have you checked your tranny fluid level? ...... I like to start with the obvious first myself
Agreed! Your symptoms could be low fluid level.
No insult intended but... needs to be checked warm, after driving a bit, and running in neutral... like Ed said.
Otherwise will read higher than actual.
Changing fluid and filter always a good idea if it's been a while.... or truck is new to you.
If not starting from stop in 1st gear, could also be the Govenor Soleniod. Trucks usually start out in second with this problem but many different scenarios have been reported.
Good Luck ........ and welcome to best CTD site out there!
RJ
Old May 27, 2009 | 06:53 PM
jrv15's Avatar
no insult taken, everyone misses the obvious. trans fluid is good to go.
Old May 29, 2009 | 04:54 PM
jrv15's Avatar
so i took it to ammco transmissions and they took off the trans pan and it was full of glittery copper flakes!!!!!!!
kellio
19
Mar 26, 2021 03:12 AM
Dauntless
15
Aug 30, 2016 08:37 PM
DJ Turbo.
Oct 13, 2011 09:11 PM
JARHEAD
Jun 26, 2004 01:44 PM
baldeagle
Sep 30, 2003 08:09 PM
