Transmission Fluid Temperature
Anybody tried using the extra capacity transmission pans on their trucks? Like the Mag Hytec DD that holds an extra 4 quarts of fluid on a 47RE....I was wondering how much they help to keep the temperature of the fluid down at a reasonable level. If it keeps the temperature down then i figure it would be worth the $300 to help extend the life of these transmissions.....
I could be wrong but I dont think the larger pan will help extend the life, its the hard parts that fail, like TC and clutches, because of the engine torque and not enough pressure to keep things applied.
I could be wrong, but call a top notch tranny shop I'm sure they would be able to clear it up for you
thanks. isn't the optimal temperature for transmission fluid to be around 140F or so? i know i've heard that it likes to be around a certain temperature to run smooth. i live in the south & it gets pretty hot in the summer. i know it wouldn't have trouble warming up in the summer, but i guess it might during winter.....temperature usually only gets down around 25-30.....I guess the PML pan might be a better option since I don't tow a whole lot.....
here is a chart that lists tranny temp vs tranny failure.
at 175, it will last 100,000miles. it basically saying that the oil degrades over time, the hotter it gets. so if you happen to run it hot once or twice, just change the oil,
trans oil is fed thru the cooler (on the block) so id suspect temps in the 190f would be normal same as coolant temp.
http://www.txchange.com/heatchrt.htm
I read a little on PML's website & they did say this:
"ATF manufacturers suggest that for every 20° above 175°F, the life of the transmission is reduced by half."
I've never seen it get in the 190 range but I'm sure that some guys do that tow & haul heavy loads a lot....I would think that an extra capacity pan would be absolutely necessary if you tow alot & wanted your transmission to last.....
on the pml pans i think you have to drill your own port if you want to put a sensor in....i think the mag hytec pans already have a port drilled for a temp sensor....they also make an adapter than you can just attach to the cooler lines to get the fluid temperature if you would rather not put a sensor in the pan....I've got an EDGE Insight on mine & it just gets the fluid temperature from the ECM....
The_Head
Nov 27, 2008 12:23 PM
OOPS
Nov 16, 2004 07:38 AM
