transmission
Old May 14, 2011 | 07:01 PM
southerman's Avatar
transmission
so when you change your trans. fluid should you always adjust the bands and clutches? i have heard you should is this correct?
Old May 15, 2011 | 10:58 PM
mstep3's Avatar
yeah, you're supposed to do the band adjustment....bolt for the rear band is underneath the trans oil pan....the front band adjustment is on driver's side of the tranmission....you can get to it at any time to adjust it....
Old May 18, 2011 | 08:58 AM
RowJ's Avatar
I would not mess with it less than every 100,000 miles, unless you get some slipping.
Over adjustment can speed up replacement interval.
RJ
Old May 18, 2011 | 12:21 PM
bill50cal's Avatar
RJ
where did you come with this?? that is like over greasing a piece of equipment caused it to wear out faster!! improper adjustment can cause problems though.
Old May 18, 2011 | 12:40 PM
RowJ's Avatar
You obviously know where I was headed with my less-than-clear comment.
OK - Frequent adjustments by us non pros opens the door to improper adjustment.
Too easy to tighten the lock nut incorrectly and over thghten the band.
JMO.
RJ
Old May 18, 2011 | 01:06 PM
bill50cal's Avatar
JMO.
RJ
it is not rocket science to do and 1/4 turn + - is OK. actually if the band is far enough out of adjustment to need readjustment chances are you are not far from real trouble. that is after initial bed in and reset.
Dauntless
15
Aug 30, 2016 08:37 PM
dsl-nut
Mar 22, 2003 12:12 PM
quantrill88
Mar 19, 2003 05:04 PM
harleydog
Mar 13, 2003 07:34 PM
jonesr2
Oct 12, 2002 04:49 PM
