trans is searching?
Old Feb 10, 2005 | 08:14 PM
2manykids's Avatar
trans is searching?
Past couple of days, the transmision has been eratically switching in and out of overdrive at or around 55 mph. Is this a bad TPS/APPS? I've read a little about them, but I'm not sure thats what it is. Where exactly is the TPS located? and can it be checked/adjusted? or do I just replace it? It only seams to act up after the truck warms up.
Old Feb 10, 2005 | 09:07 PM
ratsun's Avatar
I dont know what years it covered but there was a dealer reflash for the high gear hunting on my 98?
Old Feb 11, 2005 | 11:35 AM
Wolfeman's Avatar
This is probably caused by electrical noise. Clean the battery terminals and the grounds under the passenger side battery. If this fixes it , it will eventually come back. The best fix is a noise filter from DTT, ( about $40 ) 1 866 504 4002
Many posts on this problem, very common.
Old Feb 11, 2005 | 11:49 AM
2manykids's Avatar
Thanks for the info, but why would it start all of a sudden? Is it just because the terminals may have corroded?
Old Feb 11, 2005 | 07:00 PM
ratsun's Avatar
I realy cant say why it starts when it does? Mine started out of the blue at around 100k and the flash fixed the problem I had with mine?Outside of turnin them off and on I know nothing about this computer stuff
Old Feb 15, 2005 | 10:14 AM
bsaxon's Avatar
I had the same problem as ratsun. I believe the dealership saying something about it being caused by low batteries. It made sense to me at the time because the problem started after my batts died. The reflash fixed it
Old Feb 15, 2005 | 11:04 AM
2manykids's Avatar
believe it or not, I found it to be a broken wire in the driving light harness behind the front bumper. Ifixed the lights and the shifting problem magically went away.
Old Feb 23, 2005 | 05:31 PM
jigdog's Avatar
Not sure if this is what yours is doing but mine was shifting back and forth at lockup of the tc and near overdrive. I grounded the apps to the battery. the plug for the apps is under the bottom of the apps leftside of the engine where the cables for throttle go in. if you unwrap that wire loom going into the bottom down aways find the black wire with the yellow tracer on it . that should be the #4 on the plug.tape into that its the ground for the apps,ground it to the batt negative. i just did this to my truck and it shifts good now. i think that this includes all truck 98.5-01 not sure on the 02.
Old Feb 24, 2005 | 05:53 AM
2manykids's Avatar
Thanks jigdog, after I plugged the driving light harness back in, my problem has never come back. I should just unplug the harness again to see if the problem returns.....but its too darn cold out to play with it now.
Old Feb 24, 2005 | 06:22 AM
jigdog's Avatar
apps/tps fix
The thanks goes to "Mcgyver" he helped me through it on my truck.If you go to atsdiesel.com then click the red dodge truck ,then click the technical at the bottom,then go to the apps/tps fix it explains it out of the dodge book.if you can read the wiring diagram its easy.i talked to a guy at ats diesel and he said most of the shifting problem are solved by grounding the apps better to the battery.
wantedwolf
27
Apr 15, 2009 11:23 PM
blueandsilver02
Apr 28, 2004 10:26 PM
slttork
Mar 20, 2004 08:39 PM
Crimedog
Jan 21, 2004 07:22 AM
McGyver
Dec 10, 2002 09:37 PM
