Trans problems? HELP!
Old Jan 7, 2009 | 11:40 AM
dieselmx's Avatar
Unhappy Trans problems? HELP!
Hi everyone, Im newby on this forum and I have a questions for you, I really need help.
I have a 1999 dodge 2500 5.9L diesel, that I just bought, and Im experience and issue with it, when driving in 3rd or O/D if I stay between 1650 and 1750 rpms the truck start doing something weird, is like loosing power drops 150rpm for a second and then goes back to the original rpm and ones that its back is doing again droping rpms (is cycling, like trying to down shift and up shift)
I dont know what can I do, please help me
If you need better explanation please let me know.
Old Jan 7, 2009 | 11:56 AM
patdaly's Avatar
Do a search on lock up hunting.
Bet it is what you are experiencing.
Old Jan 7, 2009 | 01:34 PM
dozer12216's Avatar
Good possibility. These are some of things have encountered:
I have topped tranny fluid at a half pint over full. Won't hurt and may cover a VB leak.
Make sure brake switch is not out of adjustment.
Check speed sensor at rear of tranny case for connections.
Check all major high current electrical connections, batteries, alternator, fuses, ect.
Use aluminum foil and wrap(shield) the alternator wiring to battery and cover electrical components. It doesn't have to be pretty and can take off or do better if helps.
Install a old ignition condenser from Alt output terminal to housing. This helps shield from brushes arcing and weak internal condenser. Or you can buy a 75 dollar shielding kit from tranny suppliers.
Old Jan 7, 2009 | 02:32 PM
dieselmx's Avatar
Red face
sorry, but can you explain me what a lock up hunting is? Im new on this, and what the alternator wires and baterry have to do with the tranny sorry for this questions, I just want to learn.
Thanks for all your help
Old Jan 7, 2009 | 03:48 PM
smokinram99's Avatar
electrical/magnetic interferences, alternator wires with the APPS, accelerator pedal position sensor (tps on a gasser) you can try wrapping in aluminium tape.
check all the ground on your truck
have you checked for trouble codes?
Old Jan 7, 2009 | 04:03 PM
dieselmx's Avatar
I dont have any check engine light on ot any light on, but i can look for a code any way.
I will do all that today and I call let you know tomorrow guys, thanks for all your help
Old Jan 7, 2009 | 04:56 PM
klx650a2's Avatar
I also had good luck using a Ferrite choke (use 2, one on each end) of the black cable with brown tracer. I also have it wrapped with aluminum foil and the chokes and no issues whatsoever. I also reset the apps and all is now well.
Old Jan 8, 2009 | 12:39 AM
foxbag's Avatar
ive got the same problem. just started happenning and i happen to have an appointment with the local diesel shop next monday for a major service.
ill mail you what they say in a week.
Old Jan 8, 2009 | 06:15 AM
yes, you can try reset the APPS heres the procedure: http://www.cumminsforum.com/forum/98...pps-reset.html
rob
Old Jan 8, 2009 | 07:25 AM
patdaly's Avatar
dieselmx, if the alternative remedies do not fix it, and you are sure you need to replace the APPS, look for the Timbo APPS thread, much cheaper and works like a champ.
In the end, on my 97, I had to replace the TPS.
Old Jan 8, 2009 | 07:52 AM
high bid's Avatar
I found the issue to be a loose batt ground....an easy check to solve my similiar issue.
Old Jan 8, 2009 | 04:18 PM
dieselmx's Avatar
I friend of mine, told to open the hood, check all ground that you find in the Engine comparment (I found 5)
use sand paper , clean them, put them back and re drive the truck, I did it and no more issues since then, defenitly was a electrical/magnetic interferences like all you guys told me, thanks for all your help!!
Now, time to buy gauges, performance box or chip to get a little more power for towing.
Thanks again.
DJ Turbo.
Oct 13, 2011 09:11 PM
Tuf-4x4
Jun 5, 2009 07:31 PM
schoust
Jun 7, 2006 08:27 PM
pancho05
Aug 18, 2003 12:20 PM
