Trans Problems Help!!
Old Jun 7, 2006 | 11:21 AM
schoust's Avatar
Hi Guy's I have been lurking reading and learning about my new to me 95 Dodge Cummins and I have a problem that I need help with.Well I had my Neighber who is a Diesel mechanic install a cam plate and 3000 rpm gov. springs and boy what a differance the truck runs great the only problem now I'm affraid this exposed a trans problem.The truck has 130000.Does anyone know of a good trans shop that can handle this in Ct.??
Old Jun 7, 2006 | 08:27 PM
RCW's Avatar
RCW
My advice to guys looking for a first rate local transmission shop is to go have a cup of coffee with the local 4X4 and off-road accessory supply house. The rockers and mudders are the worst on transmissions and learn where to find the best and most cost effective local shops that are generally owned by another off-roader.
If you have a place to work, pick up the book and do it yourself. They are actually easier to repair than a standard, but require real care in keeping everything clean. They also take a bit of patience and some special tools to properly set the clearances. First rate kits, tools, and instruction manuals are available from DTT, places like Txchange.com, and so forth.
If none of the above work, hit DTT's website and ask them for a local shop in your area that does their performance transmissions for diesels.
DJ Turbo.
Oct 13, 2011 09:11 PM
Tuf-4x4
Jun 5, 2009 07:31 PM
dieselmx
Jan 8, 2009 04:18 PM
pancho05
Aug 18, 2003 12:20 PM
