trans problem pease help
Old Jun 26, 2007 | 04:04 PM
almar.dom's Avatar
Unhappy trans problem pease help
I have a 3500 4X4 1999 diesel dually, the problem is this.
everytime I accelerate at 40 and 45 it goes to neutral , but if a accelerate hard work fine, If anybody can tell me the type of transmission oil it used.
Any help will be appreciate .
PD> I don't leave in the states.
Old Jun 26, 2007 | 04:44 PM
patdaly's Avatar
47RE, and check your TPS.
Mine used to do this, mostly as it is getting ready to go into lockup ( 45-47 MPH).
I have heard if it is just a dirty TPS you can repidly mash the gas pedal 10-15 times ( with the truck OFF ) and it will help clean it. Another possibility is signal interference of the Alternator wire, wrapping it with foil sometimes helps. Do a search here and you should find all the info you need.
Old Jun 26, 2007 | 07:52 PM
badme's Avatar
ATF+4 is the oil it uses
Old Jun 26, 2007 | 09:11 PM
glenn-k's Avatar
I am using Dexron-MerconIII in mine per a performance dealer recommendation for firmer shifting - no problem.
Old Jun 27, 2007 | 08:54 AM
mcoleman's Avatar
The Dextron III is only for use in DTT built trannies from what I've heard. I run it in my also per my installer's advice. I would stick with the factory fill on a stock tranny.
Old Jun 27, 2007 | 10:16 PM
bama's Avatar
3 is fine,,but you may get a little convertor shudder with it.thats the purpose in using 4,it has shudder additive in it to make it slip a little.........im pretty sure all aftermarket builders use 3 after upping line pressures...ive even had one popular builder send me 2 tubes of dr.shudder additive to lose the slight shuddering issues i was having with his convertor.............bama
Les Eid
Feb 13, 2008 09:22 AM
nfsommer
Nov 9, 2007 09:36 AM
QWKRTNU
Oct 17, 2006 07:08 PM
Racerx296
Aug 28, 2006 12:42 PM
Jim Weed
Sep 30, 2003 08:53 PM
