Cam Journal Diameter?
Old Jun 23, 2007 | 10:49 PM
scout98's Avatar
Does any know the sizes of the Camshaft journals.
I am looking at pulling my cam to chase down a tapping noise and I wanted to make a sleeve to put in camshaft bore to keep the lifters out of my pan while the cam is out.
I have seen a couple of how to articles where they show a "C" shaped sleeve they put in the cam bore for this purpose. Is this a tool that can be purchased from Cummins?
Old Jun 27, 2007 | 08:46 PM
dieseldemon's Avatar
You have to hold the lifters up while you remove the cam and to do that use 1/2" dowel in the top of the lifter and then rubber band the top to hold them up yes cummins does make a kit for it but you still have to hold the lifters up first
Old Jun 27, 2007 | 09:25 PM
PourinDiesel's Avatar
The diameter you are looking for is 1.5" od pipe. Some use conduit (works well). I have also heard of people using PVC....I compared both a couple minutes ago and the PVC in 1 1/2" looks to be a dead ringer in OD compared to the conduit I use.
Old Jun 27, 2007 | 10:16 PM
scout98's Avatar
Thanks for the input
picked up my new lifters or "tappetts" as cummins calls them last night. will order the new cam in the next day or two
93flatbed
May 22, 2012 07:24 AM
etn550
Apr 1, 2010 12:12 PM
AH64ID
Jan 18, 2009 04:59 PM
XLR8R
Sep 10, 2008 12:15 AM
