Trans fix worked
Old Aug 31, 2010 | 02:08 PM
Ray Hoag's Avatar
Trans fix worked
I purchased and installed 2 ferrite filters on my negetive alternator wire from alternator to passenger side battery and wa laa no more trans hunting from 3-4 trans shifts great now.Thanks guys
Old Aug 31, 2010 | 08:36 PM
singlestackCTD's Avatar
quick question because my truck won't shift from 3rd to 4th... is this the same issue you had? driving at 55mph at or above 2,500rpm?
if so this would be awesome to know because i was going to dealership tomorrow to get pcm scanned for $80.
Old Aug 31, 2010 | 09:46 PM
nickg's Avatar
the above fix is for the torqueconverter locking and unlocking, usually caused by bad grounds or electrical noise from the alt, there are many different "fixes" some work some dont.
as for not shifting into 4th, more likely the 4th gear solenoid is failed, you would have to drop the tranny pan to replace it, easily done.
good luck at the dealer! you may or may not get good service or results, you would be better off going to a reputable transmission shop, most will diagnoise for free
Old Aug 31, 2010 | 11:25 PM
bigsmokey's Avatar
where did you get the filters?
Old Sep 1, 2010 | 04:55 PM
Dealer scanned the pcm, apparently the transmission is shifting into 4th gear. So with that being said he told me its either the solenoid is bad or a broken wire in the od wiring harness.
Old Sep 1, 2010 | 06:04 PM
mr bill's Avatar
Radio Shack has them.
Old Sep 1, 2010 | 06:32 PM
southerman's Avatar
okay im at a lost here what does this do im not use to the way my trans shifts it seems differnet from any other diesel truck i have driven it seems to shift in and out of gear alot is that what yall are talking about or im i just a retard?
Old Sep 2, 2010 | 12:07 AM
nickg's Avatar
your tranny is not shifting into 4th, your PCM thinks its in 4th,
4th gear and TC lock up are controlled by the PCM, all the other shifts are mechanically controlled via the valvebody.
odds are pretty good its the solenoid, you can use a multimeter to test the wiring harness, after you drop the tranny pan
Old Sep 2, 2010 | 05:53 AM
ok i will test the harness. is there a link to where i can buy the solenoid? thanks again for helping me out
Old Sep 2, 2010 | 07:24 AM
nickg's Avatar
I dont have any links, but would suggest you call any local tranny rebuilder and get pricing from them, I would suspect it would be around 80$
Old Sep 2, 2010 | 11:27 PM
ok, thanks alot man. no one else really helps with this question lol.
VADSLRAM
Mar 26, 2009 11:42 AM
1stGenBikeHauler
Jul 16, 2003 04:51 PM
feets
Mar 10, 2003 12:22 AM
03quadduallyho
Feb 2, 2003 07:06 PM
kingofdodge7131
Jan 25, 2003 12:05 PM
