Tranny question (MT)
Old Jan 3, 2009 | 04:27 PM
I SPEED's Avatar
Can the NV4500 be replaced with an NV5600?
What would be required to make the swap?
Old Jan 3, 2009 | 04:41 PM
Valv's Avatar
Do a search, this issue has been covered many times. On a 2nd gen you will need different flywheel, frame crossmember, and different length driveline(s).
It would be best if you find a wrecked 3rd gen and buy everything including transfer case if you have a 4x4
Old Jan 3, 2009 | 05:07 PM
Tate's Avatar
Both of my 98's have the crossmember needed for the nv5600, your 01 should as well. Depending on what model of 5600 you get, you might have to change out your clutch disc for one with a 1-3/8" input. 99-00 trannies had the 1-1/4" input shaft, 01+ have the larger one.
Old Jan 3, 2009 | 06:34 PM
thumper549's Avatar
Yes...But you might want to research ALL options.........
Old Jan 4, 2009 | 06:40 AM
I SPEED's Avatar
Define ALL options please.
Old Jan 4, 2009 | 09:09 PM
thumper549's Avatar
Well.....here I go,,,,, step n on toes...Personally I would not wast a cent on the NV As they from experience ...... crap. With out a redo upon redo. Then an other band aid and patch and main shaft and on and on
The very design is flawed. period
Spend more $$ once and be done. Get a G56
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
