tranny question
Old Jan 25, 2004 | 10:43 PM
Daryl Pliley's Avatar
Question tranny question
I have a 2001 Dodge diesel 24 valve,3/4 ton pickup with an edge chip (60 hp), 4 inch exhaust. The truck is stock as far as the motor goes other than these two upgrades. I went into a shop to price gauges for the truck and the owner of the shop said to make sure that I get the tranny valve body upgraded before I tow anything. The trailer I will be towing is a 9,000 lb. prowler fifth wheel camper trailer. He claimed that one time towing without these upgrades will make my transmission start slipping and shuddering, basically ending my transmissions life then and there. It is an automatic trans, with only 76,000 miles on it and I don't want to have to replace it already. I need some experienced help and opinions PLEASE, before I have to break the bank fixing a rookie mistake.
Old Jan 26, 2004 | 07:10 AM
Gene007's Avatar
At one time I was where you are today. Same Bombs and approximatly the same trailer weight. I never had any problems at all. I would think that it makes a difference on the grades you would be pulling.
Gene007
WarWagon
Old Jan 26, 2004 | 10:05 AM
Diesel Dave's Avatar
I also have the same mods as you minus the 4" exhaust and I have a Scotty II. I have pulled a 9,000 Wilderness 5th wheel for 2 years now throughout the Eastern US. My only tranny mod has been a Trans-go shift kit and synthetic fluid. So far, so good, and I do tow some nasty hills here in Southwestern PA. If I could scrape up a few extra bucks, I think that the torque converter would be the next on my list, but like I said, everthing is holding up for now. Good luck.
Old Jan 26, 2004 | 10:13 AM
John_P's Avatar
Daryl:
Like "Diesel Dave", I ran my 96' Dodge CTD for 98,000
miles with the "stock" transmission and only a "Trans-Go
Shift Kit." The shop that installed it increased the line
pressure from 50-55 (stock) to about 70. Like Dave, I
had no problems at all.
The "Trans-Go Shift Kits" can be found for around $50.00-
$75.00 and most any competent transmission shop can
install it for you.
Hope this has helped you some!
John_P
Old Jan 26, 2004 | 06:02 PM
Olratlr's Avatar
tranny ?
You may be allright now but if you add anymore fueling mods
you want be.
Old Jan 26, 2004 | 08:31 PM
I'd like to thank everyone that has replied to my question, at this point I have more trust in people like you that are out there pulling with your trucks than someone that is in a shop who is after my hard earned dollar. I think that the proof is in the pudding and what you guys have responded to me makes me breathe a sigh of relief! There aren't a lot of diesel shops around here but the ones that I have stopped by haven't said anything to me about the "Trans Go shift kit." The only option given to me was the valve body swap which will cost $500 installed. I really appreciate the help from you guys, and the website also which has restored hope and confidence in my overpowered, under built truck. I hope to write back at 150,000 miles with a big smile on my face and two thumbs in the air!
Old Jan 27, 2004 | 10:31 PM
TnLRacing's Avatar
What these shops are selling you when they sell you a valve body, is a assembly that has already had a shift kit of some type installed.
Old Jan 28, 2004 | 06:13 PM
I went down to a local transmission shop that has a good reputation and I personally know the owner. They were very helpful and went so far as to research all of the best possible options I had asked them about from the info that you guys gave me. And they were very agreeable to the shift kit idea and had another suggestion which was a BD Pressure Lock. After looking at my particular situation and some checking with the before mentioned companies they suggested going with the Trans Go Shift Kit. They said the shift kit will overall benefit my tranny and truck better than the Pressure Lock. To my suprise the shift kit ($300.00 installed w/tranny service and filter) was cheaper than the BD Pressure Lock ($400-425 installed and out the door). So once again I thank you guys for the great information, and help to get me pointed in the right direction.
Old Jan 29, 2004 | 09:40 PM
jigdog's Avatar
gumby how does it shift now?
Old Jan 30, 2004 | 12:41 PM
John_P's Avatar
Daryl:
Sounds like you made out pretty well! I wanted to let
you know that I also had a BD Pressure Loc on my 96'
and it worked well too. But, with the mods you and your
tranny shop did your truck should shift much better now
and last longer too!
Take care and let us know how it feels!
John_P
Black Dog
Dec 3, 2009 08:18 PM
high bid
Aug 2, 2007 06:08 PM
ezdemon72
14
Jul 29, 2005 10:05 AM
mikie1234
Dec 25, 2004 12:54 AM
silverram323
24
Nov 9, 2003 07:48 PM
