Tranmission starting in second gear
Old Jan 21, 2019 | 02:37 PM
AlpineRAM's Avatar
Originally Posted by Leonel
hello well i got the same problem i just replace the selenoid but still doing the same thing
Just the solenoid??? Or also the sensor?
It would also be helpful if you filled your signature as to model year etc of your truck.
Another possibility would be that the fluid is too cold- simple check- restart the truck when the engine and trans are at operating temp, idle in N for a minute and test again.
Old Jan 21, 2019 | 03:31 PM
Leonel's Avatar
Hi 02 dodge ram 2500 5.9 diesel yesi only replase the governor pressure selenoide also the new one look little different than the use one little smaller
Old Jan 22, 2019 | 03:13 AM
AlpineRAM's Avatar
As you may have seen in this thread- always replace sensor plus solenoid.
I would also like to ask you to do me a favor: Since English is not my mother tongue I really need you to take care to write in an understandable fashion, like spelling words correctly so I can look them up.
Old Jan 22, 2019 | 09:09 PM
Leonel's Avatar
Hi i just replaced sensor and selenoide and it worked for about 30 miles (all good) but It starts to do it again....😞 stays in second gear never go down to first gear everything else is good
Old Jan 23, 2019 | 10:50 AM
samaf's Avatar
I was having a shifting problem on my truck and found out it was a broken wire between the computer and the trans. Just something else to check. Hope you solve the problem asap.
Old Jan 23, 2019 | 11:02 AM
Leonel's Avatar
Ok thats my next step to check thank you so much but why would you think that worked for 30 miles and start doing it again??
b4wheeler
MDDTR #33
Mar 15, 2012 09:15 PM
PaulDaisy
35
Jan 14, 2007 05:46 PM
Lenn
Jul 7, 2004 02:09 PM
baldeagle
Sep 29, 2003 10:33 AM
