torque converter lockup
This is what I am using ATS TRANS COMMANDER . Just had the trans rebuilt so I had this installed as well. Haven't towed with it yet, but driving around town, I love it.
cul,
Casey
cul,
Casey
Originally posted by Mike D
This is the switch that I'm going to try to install. Although I don't really understand what the diagram says.
It looks like you cut the or/bk wire coming off the pcm, connect a 50ohm 10watt resistor in line before connecting it to a 12 relay in the open position the other side of the switch is connected to another or/bl wire in a wire group coming off the trans pin # 7. Like I said, I'm not sure if I'm reading it right.
Maybe someone with better electrical know how will step in.
I too have the same ??? as Mike here.
Can any one simplify this for the more electically challenged such as myself?
I found the black and orange wire from the PCM but am kind of lost after that. I dont really want to just ground it out if theres a chance of code issues? In all my reading on the MS this is the first time Ive seen the code issue come-up?
Thanks
93dieselZak
Jun 16, 2011 06:10 PM
tomh
Feb 14, 2005 08:26 PM
tractor-man
Oct 13, 2004 02:54 PM
Jambbii
Apr 27, 2004 02:31 PM
Jambbii
Oct 18, 2003 07:08 PM
