Time to pull the 24v
Old May 12, 2008 | 10:59 AM
mini14's Avatar
i lather the pan with grease every oil change to prevent this, it works..
Old May 13, 2008 | 12:30 AM
deuceandahalf's Avatar
Whew! I saw this post and was going to reply when I saw Haulin' in Dixie's post; which was exactly what I did when I replaced my #6 piston. JonD had me panicked there for a sec. All's well that ends well...
Old May 13, 2008 | 08:24 PM
JonD's Avatar
i painted it with 6 coats of cummins beige engine paint. should last longer than the original . now i just need to do the power steering lines out of the box. they are so rotted if i look at them wrong they will blow.
Old May 15, 2008 | 03:00 AM
cumminspower79's Avatar
Man, I guess I take it for granted linving in the dry desert where it only rains about twice a year! I cant imagine going through all the things you guys go through living in snowy and rainy areas. We get full sun about 360 days of the year! Its hot as hell, but I make sure my A/C is ice cold.
Old May 15, 2008 | 09:45 AM
Ditto - me too!
Old May 15, 2008 | 08:43 PM
IntakeRacing's Avatar
Originally Posted by nickg
From all I've read, to pull the engine you have to lift the cab, or some other crap,cant remember what it was, but if your only swapping a pan why not just pull the front axel out, its gotta be easier and faster than trying to pull the engine out, heck I bet if you unhooked the shocks the axel would drop enough to pull the pan out
...good luck
lol that won't work. the crossmember is part of the frame welded in under the pan thats what stops it from being an easy job. you can just lift the engine some.
Old May 16, 2008 | 07:02 AM
JonD's Avatar
when theres salt on the roads from november till may. its impossible to keep everything from rotting through. it dose not help that i commercially sand with this truck. with a 1 yard sander. wash it every day in the winter but still nothing works exept coating the whole under side with linseed oil.thats what i did to the 76 d300 i plow with.
king5335
26
Jan 17, 2010 07:57 PM
buddy26
16
Jan 14, 2009 07:29 PM
PourinDiesel
Competition / Pulls / OffRoad
Jul 21, 2007 12:42 PM
Bobcat698
18
Aug 3, 2006 09:23 PM
zookeeper
Jul 19, 2005 09:40 PM
