Time to pull the 24v
Old May 4, 2008 | 06:41 AM
JonD's Avatar
Its been comming for 3 years now. the rotted oil pan finally gave way. the other day . leaves a foot circle of oil when parked. got to love these trucks have to pull the engine for a $90 oil pan. I am doing all 6 injection lines while it is out. they dont even look like steel they are all salted and leaky. they have to stop salting the roads in the north east. wish me luck. next weekend. put a trans in 4 years ago. so it should up bolt fairly well.
Old May 4, 2008 | 06:57 AM
wurkenman's Avatar
Kind of sucks that you have to pull the motor for the pan, but lots of luck to you.
Old May 4, 2008 | 03:51 PM
Thundercraft's Avatar
rusted out oil pan..... you'd think that with all of the oil these things seem to ooze that they would be well preserved. Maybe route the tube from the breather so that it will oil the pan......
Old May 4, 2008 | 06:36 PM
Mopar1973man's Avatar
Wow... Your the first person I've heard about the salt eating a pan...
Old May 4, 2008 | 08:12 PM
nickg's Avatar
From all I've read, to pull the engine you have to lift the cab, or some other crap,cant remember what it was, but if your only swapping a pan why not just pull the front axel out, its gotta be easier and faster than trying to pull the engine out, heck I bet if you unhooked the shocks the axel would drop enough to pull the pan out
...good luck
Old May 4, 2008 | 08:38 PM
Now tha idea that might just work really good... I'll have to make a note of that one... (Thumb Up Smiley!)
Old May 4, 2008 | 08:46 PM
Haulin_in_Dixie's Avatar
Ahhhh jeez, pull the fan shroud, valve cover, release the front mounts, lift the engine about four inches, the pan will slide out. New pan is less than $100.
Old May 5, 2008 | 09:12 AM
Moose10's Avatar
I thought that was on the Powerchokes
Old May 5, 2008 | 12:31 PM
To pull the engine you have to pull the pan first. Pull the ac compressor and all the stuff in front of the engine except the bumper. You won't get it lined back up on the trans with the ac compressor in place.
Old May 5, 2008 | 05:19 PM
JonD's Avatar
I have pulled one before one of my friends oil pan was rotted also. as well as 4 other peole i know. the salt kills the things up here. Last summer i did 4 oil pans in power strokes. you can pull them without pulling the cab its tricky but can be done. you have to turn the engine side ways in the engine compartment then pull it forward. i have to do all 6 injection lines while its out also they leak and are rotted due to salt as well. it will be a fun weekend.
Old May 5, 2008 | 08:48 PM
You would pull an engine just to change the injector lines??? I told you how to pull the pan, done it a few times.
Old May 6, 2008 | 11:03 AM
JonD's Avatar
no i wouldnt pull it just to do injector lines. but the block is all flaking rot i figured i would pull it and strip it and paint it. but i really dont have the time. i have to many customer cars to fix. so i am going to try your way of jacking it up four inches it will be alot easier. I have to have it ready to go to pull the mini excavator to vermont on monday. thanks for the input every one.
Old May 10, 2008 | 07:03 PM
JonD's Avatar
oil pan is in. have to pull the radiator tommoro to power wash all the oil out of it. over heats sometimes towing. the thing is packed halfway down with oil. thanks hauling in dixie for the info on the pan swap. way easier than pulling the engine. i will do the lines another weekend. they are not leaking. just really rotted. thanks
Old May 10, 2008 | 09:23 PM
Ok Jon I also have something to say about the overheating. If it has the original thermostat in it, or regardless, change it out for an OEM, not aftermarket, 180 degree thermostat. Get the real Cummins part. It will make a big difference on the pulling heat up.
Old May 11, 2008 | 11:25 PM
SIXSLUG's Avatar
You should've rhino lined the outside of that oil pan before you put it in. How about stainless injector lines? anyone make them?
Kurt
