thermostat
Old Jul 28, 2008 | 03:45 PM
richf's Avatar
thermostat
my truck is starting to run a little hot going up hills and on hot days.the temp goes over 190 consistantly and then settles back down below.it has 195k on it and i think it is the orig thermostat.i plan on changing the thermostat soon here.should i go with a 190 or 180 degree.should i get it through the dealer or napa.coolant is good.i changed it a few months ago.thanks
Old Jul 28, 2008 | 03:58 PM
Busboy's Avatar
Your radiator could be plugged up from the crankcase vent bottle (puke bottle) Its amazing just how much crud can accumulate.
Old Jul 28, 2008 | 04:01 PM
06RAM2500's Avatar
Radiator is probably getting plugged with dirt and oil from the blow-by bottle.Go with a 190* and Napa coolant will work, just add some RP additive.
Old Jul 28, 2008 | 04:34 PM
Diesel Doc's Avatar
you shouldn't lose more than a few ounces of water changing the thermo. I have done it without draining the rad and barely spilled aything
Old Jul 28, 2008 | 05:21 PM
2002-5.9's Avatar
100,000 miles and over 30% blockage. The radiator looked fine untill I got it out. This is the radiator side that faces the A/C condenser.
https://www.dieseltruckresource.com/...1&d=1217283623
Old Jul 29, 2008 | 12:12 PM
SIXSLUG's Avatar
Doesn't sound like a bad thermo if you're temps aren't fluctuating or your not warming up. The 24v like a 190. If you are gonna flush and fill get the rear end up as high as you can to drain the block better. Run a straight premix coolant, you don't want a lot of water in your system. I ran the Delo premix. Cleaning the radiator exterior is probably your real problem, though.
Kurt
Old Jul 29, 2008 | 12:50 PM
RowJ's Avatar
Originally Posted by SIXSLUG
.... The 24v like a 190. Kurt
Depending on your location (richf's is not given).......I disagree.
My 02 loves the Cummins 180* T-Stat, especially in the summer. Takes a bit longer to warm up in winter but no biggy. Flows much better. At track, my old 190* would quickly cook up to 220-230*. The 180* never gets higher that 190*.
The Dodge 190* T-stat has a plate on it to improve warm up but I'm convinced it reduces flow somehow.
Cummins T-Stats have no such plate. If interested...The 180* Cummins is PN# 3967195.
Your Radiator/CAC/Condenser may also need cleaning. Do a search on back flushing tool. Lots of info. Can start HERE.
RJ
Old Jul 30, 2008 | 08:06 AM
ironbutt's Avatar
I had a dirty radiator thanks to the vapors from the puke bottle. First thing I did was to add the hose to the puke bottle[now its behind the tranny cross brace on the frame]. then I cleaned the dirty dust and debris from the radiator core, then a new T-stat. My stock thermostat was 190 degree, but when I went to the Cummins shop they asked for the motor # and said it called for 180 degree, and so that is what I bought. now i can't get it to go over 180 ,even towing uphill with the temps outside in the high 90's.
Old Jul 30, 2008 | 11:34 AM
SIXSLUG's Avatar
After researching this site before doing my flush and fill I noticed the 190 seemed to be the temp of choice for the 01, suggested by members and Cummins, so that's what I went with and I haven't had any hot temps that I've noticed, but I am in the Pacific Northwest which is a tad cooler than Texas!
Many responded that diesels like to run hot, but 190 isn't really hot compared to gassers that run 200 or more with emissions. I tend to go with what suggested by the manufacturer, in this case Cummins, when I chose to stick with the stock thermostat.
A lower stat may be good medicine in the hotter regions, hence I agree with RowJ re: the 180 if you get higher than average summer temps.
Kurt
Old Jul 31, 2008 | 08:22 PM
richf's Avatar
thanks.i am used to marine diesels that run 165-170 at 1500 for hours-days on end.
Bookshelf
May 30, 2009 01:17 AM
mechanic
Mar 25, 2003 08:45 AM
BigBlue
Dec 10, 2002 10:55 AM
Crazy Horse
Nov 16, 2002 01:00 AM
dart racer
Nov 11, 2002 10:10 AM
