testing track bar
Old Mar 26, 2005 | 09:22 PM
RAM2940's Avatar
testing track bar
How can i tell if my track bar is bad? I got under the truck and had someone rock the steering wheel back and forth and noticed about 1/16 play up and down movement. Also while rocking steering wheel, noticed small side to side play in the tie rods are those considered bad if they have any movement. Also was able to rotate the tie rod bar up and down while rocking steering wheel, is that normal. Thanks for responses.
Old Mar 26, 2005 | 09:48 PM
Whitmore's Avatar
Sounds like its on its way to being too much, put the front end up on jacks and check for slop in all directions, prolly start savin fer track bar and tierod ends, if these are bad the ball joints are right behind them.How is yer tire wear doing?..........Sorry JMO
Old Mar 27, 2005 | 02:32 AM
Supermod56's Avatar
Also a good way to determine if they are bad is if the thing wanders all over the road. Pretty common for these things, already replaced mine once. Getting a DSS next, that helps a lot.
Tom
2001.5 2500 4X4 5-Spd LB QC Black. Catcher ECM, DD Stage-1's, AFE, Bully Dog 4" pipe, ATS Exhaust Manifold, Silencer Ring MIA, JAKE Brake w/shifter switch, Geno's Banjo's, 3 Autometer's on the A-Pillar, Gear Vendor's O/D, Firestone Air Bags, Redline Oil throughout.
Old Mar 27, 2005 | 07:28 AM
Dodge Demon's Avatar
Solid Steel.biz is comming out with a new adjustable track bar with rubber bushings both ends like the 2003 and up, it will fit from 94 to 2002 with thier track bar bracket and from 2003 to 2005 it will replace the original,no modifacation nessasary. The rubber bushings are special made and are superior to Dodges original 2003 track bar bushings. I see its on thier web site-www.solidsteel.biz-check it out.
Old Mar 27, 2005 | 08:22 AM
RAM2940's Avatar
Its really strange but there is about 4" of play in the steering wheel(2" side to side before you feel any steering) but the truck tracks straight. It just takes a lot of sawing in the curves. Just wondering if you think the steering box is worn or does it need the over center adjustment done.
CTD2001
Aug 22, 2009 10:03 PM
Dinner
May 29, 2007 02:02 PM
kwillis-a
Jan 25, 2007 09:10 PM
Stroked-Z
Apr 2, 2006 09:54 PM
