Synchromesh in a NV4500?
Old Oct 11, 2004 | 07:06 PM
jlells01's Avatar
Anyone ever tried it?
Old Oct 12, 2004 | 12:37 AM
KATOOM's Avatar
What are you talking about?
Old Oct 12, 2004 | 02:29 AM
jlells01's Avatar
Pennzoil Synchromesh.
Old Oct 12, 2004 | 07:52 AM
wmatt's Avatar
I run it in my NV5600. Shifts are pretty smooth and it meets that MS9224 requirement for the six speeds.
Old Oct 13, 2004 | 11:43 PM
KATOOM's Avatar
Sorry I didnt get it the first time. I also thought about changing the oil in my 5spd but after looking in to it I found that the OEM stuff is expensive but really good. It's supposed to run cooler than other tested oils and the main reason it was choosen was because the NV4500 has carbon fiber synchro's which can take a beating with other oils. Then I checked the oil in mine and it was still honey colored. I also hear you can get the same stuff from GM for less money. Didnt check though.
Old Oct 14, 2004 | 08:28 PM
Ruralmedic's Avatar
It may be too thin for the NV4500. The OEM fill is Castrol Syntorq LT, which is a 75W-85 GL-4 transmission gear lube. GL-4 lubes contain 1/2 the sulfur and phosphorus content of the more common GL-5 gear lubes for differentials. This allows proper function of the synchros, and is easier on the yellow metals in transmissions.
A 50/50 mix of Redline's synthetic MTL/MT-90 transmission lube at $7-$8 a quart is an alternative to the expensive OEM fluid.
quicksilvr
Aug 24, 2010 09:45 PM
SilverSootXpres
Mar 23, 2010 07:18 PM
Mark Hodowanec
Jun 17, 2009 12:42 PM
Rod_Montana
Nov 27, 2007 11:32 AM
Hummin Cummins
Dec 25, 2002 12:29 AM
