strange noise
Old Sep 14, 2006 | 12:14 AM
slowflyer2112's Avatar
strange noise
Help
truck started making a strange noise when accelerating. It sounds like metal on metal scraping and only makes noise when the boost comes up past 12lbs and increases as the boost increases. checked the turbo for play and every thing seams OK. ????
Old Sep 14, 2006 | 08:07 AM
dieselrob's Avatar
Check for a bad u joint somewhere, they can make alot of noise. Try and locate the noise more specific. That will help us help you.
Old Sep 14, 2006 | 10:47 AM
Its more like a high pitch squeal, its not speed related.
If i'm on a hill and the boost comes up it makes the noise and if I let off on the throttle and the boost drops below 12 lbs it stops. wierd.
Old Sep 14, 2006 | 10:50 AM
dodgezilla04's Avatar
your turbo is loosing its bearings? when it does, it can grenade and shrapnel the motor. hopefully most of it gets caught in the ic.
you checked endplay. what about radial?
you know, up and down, and fore and aft?
good luck, that is a weird one.
Old Sep 14, 2006 | 05:43 PM
Tate's Avatar
Just a thought, but have you checked for an exhaust leak at the manifold? I hear they make a whole lot of noise. Mike Holmen had this happen, and thought his engine was on the way out. The leak would get worse as boost came up.
torq
19
Dec 30, 2005 05:59 PM
heavyg
Jun 24, 2003 07:43 AM
DarrellB
Mar 3, 2003 06:26 PM
Gregor
Dec 3, 2002 12:18 AM
heavyg
Oct 25, 2002 05:06 AM
