still not starting
Old Apr 14, 2004 | 09:43 PM
02DODGE's Avatar
still not starting
Hey I have been on here and asked this question a couple of times. What makes a diesel not start? If you park it facing downhill it starts every time if you park it facing uphill or on level ground you have to crank for a good while. I have replaced both pumps and recently all the lines from the tank to the lift pump. For a week after replacing the lines it started no matter what. Now it is back to the same old starting routine. Any suggestions would really help.
Old Apr 14, 2004 | 09:55 PM
j-fox's Avatar
A friend had one doing that and we found it was the cap for the fuel filter. It was loose. 2001 3500.
Old Apr 15, 2004 | 07:50 AM
Smokee's Avatar
It has to be getting air some place. Pressurize from the filler spout and listen along the lines for the leak.
Old Apr 15, 2004 | 05:42 PM
02DODGE's Avatar
Stupid Question but how do you keep air from coming out the vent in the tank?
Old Apr 15, 2004 | 09:18 PM
AaronT's Avatar
Could be overflow valve is worn and allows the system to drain back to the tank.
03RAM2500
Dec 6, 2008 09:58 PM
ramit16
Jan 10, 2007 12:14 PM
ViperSBT
Jan 12, 2006 05:14 AM
salty mule
Mar 23, 2004 07:37 PM
admin
16
Aug 17, 2003 10:07 AM
