Steering box movement???
Should there be any movement in the steering gear box? The shaft out of the bottom of the box moves up and own about 1/16" when the wheels are turned. Loonked over everting on the front end and all is tight except this.
adjusting the nut will not correct for pitman arm in and out play, if you back off the screw it will cause excessive play. IIRC you would have to remove a shim from under the plate that the jam nut is on
here is a link to adjust the steering box, can be done in the truck, in about 15mins, no special tools required, as the "collar" and be moved/tightened with a small punch/chisel
http://dodgeram.org/tech/mods/steeri...ear/Adjust.htm
here is more info on steering issues and tsb's
http://dodgeram.org/tech/troubleshoot/steering.htm
Shaft should not move. Track down a diagram from a FSM & you'll see. There is a bearing and oil sea around the shaft. I've had 4 boxes fail at the oil seal. 1st box came in the truck & started leaking. 2 AGR boxes failed suddenly when the lock ring let loose (poor quality control). Final AGR (as in last one I'll ever own) wouldn't adjust and started leaking in under 5,000 mi. Point is engine is heavy, pitman leverage is great, QC is poor so you can expect a leak. Note: AGR boxes failed in spite of the DSS. Current box is A-1 Cardone with lifetime parts & labor warranty. It really isn't exciting. I intent to try 1 more Cardone box when this fails then go to Redhead next.
tfarmer96
Jan 11, 2020 12:50 PM
mrwaters
Jun 27, 2005 07:56 PM
md11jetdriver
Mar 22, 2004 06:08 AM
