Starting problems
Old Dec 10, 2007 | 12:41 PM
12valve's Avatar
Starting problems
I have a 98, that doesnt start right up when the ignition switch is turned on, you have to wait about 15 seconds after turning the key to on, then the Wait to start light will go on, and the lift pump will start pumping.
(which on my other 98s happens right at the time the ign. switch is turned to on)
if i start cranking right after turning the switch on, it will crank about 15 seconds till it'll start. somethings not right.
possible problems?
it has a new lp (15 psi idle) and a reman vp44
stock engine
fourthandgoal
88
Dec 27, 2011 05:39 AM
DJ Turbo.
Oct 13, 2011 09:11 PM
RED99CTD
Apr 20, 2011 08:08 AM
abc4yew
Mar 15, 2007 11:55 PM
doodah
17
Dec 17, 2002 12:55 PM
