So just to double check...
Old Jun 2, 2005 | 07:42 AM
screaminbanana's Avatar
Muted User
If you bump start the engine and stick your head under the hood and dont hear anything at all does that mean the lift pump is dead?
Old Jun 2, 2005 | 08:04 AM
crobtex's Avatar
I can hear mine from inside the cab. Put a gage on it and find out for sure, but it sounds like it's gone..
Old Jun 2, 2005 | 08:50 AM
CTD NUT's Avatar
After you bump the starter, stick your head under the hood and listen for it......it should be very audible.........As Crobtex said, I have no problem hearing mine in the cab without the engine running......before you turf the pump, just double check to make sure it is getting power.....it probably is......most likely the LP is pooched.
unioncreek
Jul 11, 2013 06:33 PM
Adam3291
May 2, 2008 10:08 PM
charger 69
Jun 4, 2007 02:09 AM
Jordan5687
Mar 1, 2007 11:15 AM
Dieseldude4x4
Jan 15, 2003 06:17 AM
