smoke in upper rpms
Old Sep 12, 2006 | 06:27 PM
soot shooter's Avatar
smoke in upper rpms
when hard on the throtle my 01 smokes in the upper rpms. i have never noticed this before and would like to know is this normal
Old Sep 12, 2006 | 06:41 PM
coalburner400's Avatar
Not enough boost to complete combustion... do you have any mods?
Old Sep 12, 2006 | 08:00 PM
12valve's Avatar
dirty air filter?
did an intercooler boot blow off?
Old Sep 12, 2006 | 10:11 PM
there is no mods on right now and the air filter is brand new didn't see a boot that was off
Old Sep 13, 2006 | 04:31 AM
lovinCTD59's Avatar
My 01 did the same thing, couldnt notice at day when driving unless i was following the truck then you sould see a little.... but at night above 2000 rpms you could see a slight haze, from the exhaust in the mirror. The truck Then was Bone stock... I wouldnt worry about it unless you are pushing out a fog line of black smoke with a stock truck...
Old Sep 13, 2006 | 07:39 AM
jrs_dodge_diesel's Avatar
If you are concerned about it, pull out and clean the IAT (Intake Air Temp) and MAP (Manifold Absolute Pressure) sensors and clean them with Electronics cleaner. Do not use brake cleaner, use electronics cleaner which is perfectly safe for electrical items and sensors.
I cleaned my IAt sensor (I don't have the correct socket to pull the MAP) and it helped clear the smoke some, and the IAT was filthy when I pulled it. The IAT and MAP sensors are directly involve with fueling and if they are reading funny then your fueling will be off too.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
gear jammer 91"
Jun 12, 2009 09:36 PM
steve21
Sep 12, 2008 12:34 PM
kyle_truck_pull
Apr 8, 2008 07:53 PM
