white smoke and no power in upper rpm?
Old Jun 10, 2009 | 10:03 PM
gear jammer 91"'s Avatar
My neighbor has a 93 xtra cab dually 2wd with a auto that is almost completely stock with just under 100k miles. He was driving it the other day and it suddenly lost power in the upper rpm, speeds over 40mph. At the same time it's doing this it's blowing white smoke. He says that it runs fine at lower rpm and slower speeds, but it has no power on the top end. I was thinking it was either a timing issue, or air in the fuel? What do you guys think?
Old Jun 10, 2009 | 11:48 PM
Alwaysworking's Avatar
alwaysonDTR
air in the fuel system, maybe a bad lift pump?
Old Jun 10, 2009 | 11:51 PM
Ramrod90's Avatar
It could be a super clogged filter or some junk in the pickup assy. in the tank.
I wouldn't suggest running it too hard while it's doing that because white smoke means that it is running lean and there is a bigger chance of burning up valve seats/seals in that condition. Just a thought but it may have something to do with the ksb, any connection issues there?
Old Jun 10, 2009 | 11:53 PM
alwaysonDTR
i dont think its cold enough for the ksb to matter
Old Jun 11, 2009 | 12:13 AM
GLHS's Avatar
Sounds similar to what just happened to mine in a thread I started a couple days ago.
Still trying to figure it out
Old Jun 11, 2009 | 08:52 AM
apwatson50's Avatar
KISS fuel filter first
Old Jun 11, 2009 | 05:09 PM
Second. All in favor?
Old Jun 11, 2009 | 05:19 PM
Wettstein's Avatar
sounds good to me
mine did that, i changed the fuel and problem solved
we have a lot of problems with the five tons in the army out here at ft irwin with jp8 and the blowing sand messes up the fuel filters
Old Jun 11, 2009 | 11:26 PM
He said the fuel filter had been changed recently. I'm leaning towards air in the too, whats the best way to check for that? He doesn't drive the truck much and he's pretty good to it when he does.
Old Jun 12, 2009 | 01:16 AM
alwaysonDTR
if he just changed the fuel filter, check the fuel heater gasket thats usally the cuprit
Old Jun 12, 2009 | 09:36 PM
I talked to the neighbor today, he thinks he has water in the fuel since he rarely drives the truck. He is gonna change the fuel filter again this weekend.
EdmontonCanada
37
Feb 4, 2016 12:02 PM
jefjsak
Jan 15, 2015 03:44 PM
Lil Dog
Aug 9, 2004 04:20 PM
NOTSTK
Apr 22, 2004 10:58 PM
fishin fever
Feb 22, 2004 08:32 PM
