Slow start
Old Feb 12, 2015 | 02:18 AM
1fast6's Avatar
Question Slow start
My '99 starts slow. Just put brand new red tops in it but it still turns over slow. Any ideas? Maybe starter brushes?
Old Feb 12, 2015 | 04:44 AM
Keine Täuschung's Avatar
how is the condition of your battery cables?
make sure those are nice and clean and connections are all solid on the batteries and the connecting points
also when you say cranking slow do you mean that the engine cranks slow or the engine cranks fine and is slow to start because if it is slow to start then we have other issues probably fuel system related
Old Feb 12, 2015 | 06:02 AM
1fast6's Avatar
I will check the grounds and change the cables. It turns over slow like a low battery.
Old Feb 12, 2015 | 08:25 AM
patdaly's Avatar
Could be starter as well.
Don't go with a cheap rebuild, most aren't worth the time it takes to put them on.
Old Feb 12, 2015 | 10:32 PM
Oh yeah for sure I would check out the starter let me ask you do you the starter to restart your truck after a fuel filter change because that can have adverse effects on it
Old Feb 13, 2015 | 02:47 PM
KATOOM's Avatar
Did it slow crank before the red tops? If no then I'd be looking at a faulty battery first.
Corrosion can be a big problem in places where road salts are used. Battery cables can get corroded on the inside too.
And never exchange your Denso OEM starter for an over the counter "lifetime replacement" unit. Find someone to test and fix yours first. The contacts could be partially fried too and not making a good connection.
Old Feb 25, 2015 | 08:16 AM
1fast6's Avatar
Guess I'll be pulling the starter today. Replaced all the battery cables with 2/0 cable and military style terminals. They needed to be replaced regardless as they were in poor shape....
Old Feb 25, 2015 | 08:27 AM
Whatcha mean by military style terminals? Pic?
Old Feb 25, 2015 | 09:18 AM
KATOOM's Avatar
You need either military or marine style so you can connect multiple batteries together. Military is better in my opinion.....
Brad4406
13
Oct 21, 2013 10:16 AM
Hunky Dory
May 13, 2013 08:09 PM
PsRumors
Dec 6, 2005 03:29 PM
thomasbarnett
16
Oct 13, 2005 07:03 PM
edwinsmith
Mar 10, 2005 11:00 AM
