Slow Off The Start
Old Oct 11, 2005 | 09:42 PM
thomasbarnett's Avatar
Slow Off The Start
I Have A 1996 Dodge 2500 4x4 When I Floor It It Doesnt Want To Go Until I Hit About 2000rpm Iget About 35 Pounds Of Boost And After 60mph It Puts Me Back In The Seat.it Wont Even Blow Smoke When I Floor It Any Insight Helpful
Old Oct 11, 2005 | 09:43 PM
phox_mulder's Avatar
Sounds like a stock Dodge torque converter, if you have an automatic tranny.
phox
Old Oct 11, 2005 | 10:05 PM
Smkndzl's Avatar
I would check your AFC diaphram and make sure you dont have a leak. you could be leaking till you really get some boost building and then seem like normal.
Old Oct 11, 2005 | 10:06 PM
keithplacervill's Avatar
sound like it could be timming?
Old Oct 12, 2005 | 07:48 AM
MnTom's Avatar
The first thing I would try is adjusting the position of the AFC. I have been 'playing' with mine and with it all the way back it will do what you say yours is doing. Put it about 3/4 forward and then pull the cap out of the top and adjust the star wheel to your liking. If you got too far forward you can kill your mileage (that's why I have been playing with mine).
Tom
Old Oct 12, 2005 | 09:12 AM
TxDiesel007's Avatar
Tom
What he said..
I would guess timing has slipped, but i have no experience with the auto trannies, you arent getting smoke and you are getting tossed into the seat, sounds to me like ur housing could be at stock position as well, plate change maybe?
Tx
Old Oct 12, 2005 | 07:59 PM
Im Fairly New To The Ctd What Exactly Is My Afc And How Do I Move It Forward Also When I Pull A Small Trailer I Blow Alot Of White Smoke
Old Oct 12, 2005 | 08:04 PM
MnTom's Avatar
The AFC plate is just above the fuel plate on top of the rear of the fuel pump. Since you said you get a lot of white smoke, that says your timing has slipped. Take a look here and you will have some good info: http://dodgeram.org/tech/dsl/FAQ/timing.htm
Be sure to look at the TSB posted there. That is the insructions for how to time it.
Tom
Old Oct 12, 2005 | 08:23 PM
Thanks Tom That Was Very Helpful Ithink I Should Advance My Timing First But How Do I Adjust My Afc
Old Oct 12, 2005 | 08:38 PM
Where Should My Timing Be For Overall Best Performance
Old Oct 12, 2005 | 09:40 PM
Usually
16-16.5 degrees is the best overall setting for timing..
Here is my newbie tutorial.. enjoy and sorry if its redundant...
https://www.dieseltruckresource.com/...ad.php?t=78573
Tx
Old Oct 12, 2005 | 10:12 PM
DustyRock's Avatar
phox
I think Phox hit the nail on the head. What happens is the torque converter "locks up" then you can put the power to the ground. Thats why you feel all the power after 50-60 mph in overdrive. The stock converter has a poor fluid coupling so all you get is a lot of RPMs without much forward momentum.......until the lockup happens then hang on. I had the same problem until I got an after market torque converter from Dave Goerend. It works great, just like it should have from the Dodge factory.
Old Oct 12, 2005 | 10:24 PM
Smile
Thanks For The Info This Will Help Alot
Old Oct 12, 2005 | 10:26 PM
What Kind Of Torque Converter And About How Much
Old Oct 12, 2005 | 10:43 PM
DustyRock's Avatar
Thomas there are many vendors that make torque converters for our trucks. DTT, ATS, BD, Dave Goerend and others. After a lot of research I purchased a triple disk converter from Dave and really like it a lot. You cant beat the warranty and Dave is a great guy to deal with and is very informative. I have a pic of the TC in my gallery.
Dusty
