Showing code P 1693 ??
Old Jan 3, 2007 | 07:41 PM
ross236's Avatar
Need a little help please
I have just installed an Edge EZ, did all of the hook up's except the power unit (or module) and started it up, then I turned it off and hooked up the unit but then I noticed the check engine light was on. Truck drives great, I think all I need is too clear the code, any Ideas guys
Thank you
Ross
Old Jan 3, 2007 | 08:33 PM
phox_mulder's Avatar
The 1693 is the code telling you there is or was a code.
More than likely related to the MAP sensor which the computer thought was bad when the EZ wasn't powering it.
If you want to find out what the real code is, you will need a scanner,
or even the Dodge DRB Scantool at the Dealership to find out what it was.
Most likely, you'll also need the same scanner to clear the 1693 and whatever the hidden code is.
phox
Old Jan 3, 2007 | 08:36 PM
ross236's Avatar
Thank you
I have a buddy that has a code reader, not sure if his will clear it though.
I will try that first, then off to the dealer i will go
Old Jan 4, 2007 | 11:45 AM
RowJ's Avatar
You could just ignore it!
If the condition that caused the code (which I think you identified) does not reoccur... the code will disappear after 10(?) starts.
RJ
Old Jan 4, 2007 | 12:03 PM
1Rodeoguy's Avatar
This code appears if you start the truck without the unit connected it means something about a low circuit. I usually screw around and trip it and have to remove it. It does not effect anything! In fact it has been on sice I triped it several months ago. I would ignore it but since your buddy has the tool to remove it, go for it!
bayshorebrawler
Jun 13, 2011 08:32 PM
Warponee
Jan 8, 2009 09:27 PM
masterphreak
May 11, 2006 05:07 PM
j
Mar 9, 2004 11:45 AM
roadrat
Jan 18, 2004 03:07 PM
