Shifting problem?
Old Dec 8, 2009 | 03:14 AM
Rich Detert's Avatar
Shifting problem?
What speed should an auto trans be shifting into Overdrive under normal circumstances?
When mines cold it won't to into O/D till I'm going 50-55 (usually closer to 55).
It does it sometimes even when it's warmed up, flat ground, no load.
Old Dec 8, 2009 | 06:49 AM
DodgeRamdiese01's Avatar
mine used to do it around 47 when I adjusted the bands it went up a little, like 52
Old Dec 8, 2009 | 09:43 AM
sheriffav8r's Avatar
Also depends on what size tires you're running. I believe is shifts on RPM so if tires are changed it will change the OD speed. Also depends on if you have it floored or not. With an easy throttle, mine used to do it at around 45 but now not until 50 with the larger tires....
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
fourwhls00
Aug 4, 2004 10:04 PM
Cumminsdude
Aug 13, 2003 12:50 PM
warden
Feb 23, 2003 10:20 AM
