Shifting problem 1-2
Old Mar 5, 2010 | 03:09 PM
onelugnut's Avatar
The problem I am having is under light pedal pressure first thing in the morning. It feels like it is shifting back and forth 1-2. Once warmed or a little more pedal it is fine. I just changed the fluid and adjusted the bands.
I just dont like to romp on it going down the street
Old Mar 10, 2010 | 09:50 AM
onelugnut's Avatar
bump
Old Mar 10, 2010 | 12:01 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Are you sure it's shifting back and forth from 1st and 2nd? Are the RPM's jumping all over? If so, what does the fluid look like? Dirty? Burned? Low? These tranny's are kinda cold blooded.
If the RPM's aren't jumping all over, maybe it's not actually shifting back and forth. The feeling your having may be the heatergrid turning on and off to heat up the motor's intake. Which causes a major ampage draw, which means the alternator has to work harder, which puts a drag on the motor.
Old Mar 10, 2010 | 09:50 PM
onelugnut's Avatar
The fluid and the filter are good. I just replaced them a couple weeks ago. It feels like it is hunting between gears and the rpms move up and down. I dont want to take it to a trans shop if some has a fix for it.
Old Mar 11, 2010 | 04:27 PM
SIXSLUG's Avatar
Check and clean all your grounds.
Brendan
Oct 17, 2007 11:12 AM
98 Ram 24V
Dec 24, 2005 10:19 AM
fourwhls00
Aug 4, 2004 10:04 PM
Cumminsdude
Aug 13, 2003 12:50 PM
warden
Feb 23, 2003 10:20 AM
