Scan Guage II
Old Dec 11, 2010 | 04:19 PM
triker888's Avatar
Scan Guage II
Does anyone know what the MAP pressure should be that the Scan Guage reads? Mine is reading 30/35 psi. Is this too much or too little.
I like the Scan Guage, but the instruction booklet leaves something to be desired. At least by me.
Old Dec 11, 2010 | 05:05 PM
rickf's Avatar
The scan Gauge will only tell you what the vehicle computer see's. What it is most likely reading is atmospheric pressure plus boost pressure which would equal around 35 at sea level
Old Dec 11, 2010 | 06:12 PM
triker888's Avatar
So, I am to think that the Scan Guage MAP reading minus 14.7 would be an approximation of the turbo boost pressure?
Anybody else have any info they want to share about using the Scan Guage?
Old Dec 11, 2010 | 06:36 PM
1-2-3's Avatar
Just a plain ole guy
I've tried one and it just doesn't tell you enuff to be worth the cost.
Old Dec 11, 2010 | 06:48 PM
rickf's Avatar
What does it show for a MAP reading with the key on but engine off? If it is showing atmospheric then you have your answer. I will be putting my Snap-On scanner on mine tomorrow to check for codes and I will see what the MAP reads.
Rick
Old Dec 12, 2010 | 11:22 AM
Ed ke6bnl's Avatar
I have to subtract 14.7 from my reading to be accurate. There may be some better alternative to the scan gauge. some obdII blue tooth reader to your Iphone or droid and cheaper and probably many others; Ed
Old Dec 12, 2010 | 12:53 PM
rickf's Avatar
They ALL read the computer on the vehicle and will give the same info. You can't just automatically say total map minus 14.7 is my boost because that atmospheric pressure changes with altitude and even with weather.
Rick
Blessed
Jan 25, 2005 06:42 PM
BDR2500
Jan 18, 2005 04:55 PM
SoCal-305
17
Aug 8, 2004 11:19 AM
TEXASTURBO
Mar 16, 2004 05:03 AM
360ramcharger
Aug 14, 2003 10:49 AM
