Rising FUEL pressure!?
Old Jun 17, 2004 | 06:07 PM
Cummnzpowr's Avatar
Question Rising FUEL pressure!?
Holley Blue was idling at 12.5 yesterday, now all of a sudden it's idling at 14 !? ...what would cause the pressure to rise...{mechanical isspro gauge with snubber valve on it}...about the same cruising PSI 9-10..
Old Jun 17, 2004 | 07:07 PM
AlpineRAM's Avatar
Pressure regulator in the pump getting dirty I'd assume. Take it out and clean it. (the one big screw on the pump case, there's a spring in there and a piston)
HTH
AlpineRAM
Old Jun 18, 2004 | 01:16 AM
duner's Avatar
if the snubber is adjusted to tight it will peak and hold. might want to check it
Old Jun 19, 2004 | 01:39 AM
Huff nPuff's Avatar
Could be a change in pump supply voltage
Check connections positive and ground,also a heavy electrical load could be turning on and of such as A/C.Merv
mstep3
Oct 17, 2011 04:39 AM
sleepr tsi
Nov 13, 2008 06:20 PM
CaptainChrysler
Apr 4, 2008 12:21 PM
djbikeman
Mar 24, 2006 04:42 PM
dma251
Mar 14, 2004 07:11 AM
