ring seating
Old Aug 17, 2005 | 11:24 PM
CTD99's Avatar
ring seating
I'm installing a Diesel Dynamics camshaft while I have the engine apart... I'm replacing all the piston rings as part of the rebuild. DD tells me that the first step for break-in of the cam is this:
"At first start-up run engine at 2000rpm for 20 mins."
My question is, will this be detrimental to the seating of the piston rings? I've been told in the past that constant rpm for an extended period of time is bad for break-in on these engines...
Thanks.
~ Russ
Old Aug 18, 2005 | 12:10 AM
AAmeeting's Avatar
Ask DD.
Old Aug 18, 2005 | 07:09 AM
Supermod56's Avatar
No, it will be fine, steady RPM for a long time is detrimental to ring seating on any motor. I have built tons of motors with new rings and a new cam, just keep it at the steady RPM in the driveway to break the cam in, DO NOT let it idle until the 20 minutes has passed. Then take it out and drive it and vary your speed to seat the rings, and don't run it too hard. 20 minutes is not an extended period of time, just don't take it on the freeway for a 100 miles. It will blow a little oil until they seat, you did hone the bores, right??
Tom
Old Aug 18, 2005 | 08:31 AM
CTD99's Avatar
Originally posted by AAmeeting
Ask DD.
Gee... why didn't I think of that! ... I'm still waiting for a response from DD.
Old Aug 18, 2005 | 08:34 AM
CTD99's Avatar
Thanks Tom, and no, I didn't hone the bores... aside from the cylinder that was repaired (obviously). They're all in good shape and the guy who sleeved the cylinder felt the same way so we left 'em alone.
~ Russ
Old Aug 18, 2005 | 09:23 AM
Supermod56's Avatar
You should be OK, although I have never done that, I have seen it work.
Tom
Old Aug 18, 2005 | 09:47 AM
apwatson50's Avatar
You should cross hatch hone all the bores as that will help speed the process and seat the rings better/faster.
Old Aug 18, 2005 | 04:08 PM
CTD99's Avatar
So how many miles does it usually take for the rings to seat?
Old Aug 19, 2005 | 08:55 PM
AAmeeting's Avatar
Cummins Site says 5000. And not to use synthetic oil during this period. How about that!
Old Aug 19, 2005 | 11:02 PM
Supermod56's Avatar
It should start to seat at about 1K, fully seated at 5, and AA Meeting is correct, No Synthetic oil!!!!
Old Aug 20, 2005 | 02:22 AM
CTD99's Avatar
I'm well aware of the "no synthetic" rule... thanks for the other info though.
Old Aug 20, 2005 | 10:55 AM
Timmay2's Avatar
Just dont let it idle very long.. keep the rev's up a bit.. Get out on the highway and mash the pedal a few times and your rings are seated.
sit back and enjoy.
If they take 5,000 miles to seat, you either got some washed cylinder walls that didnt get honed/hatched or the rings are crappy.
tacohat
Aug 4, 2006 12:59 PM
HaulinBut
May 12, 2006 03:06 PM
Crimedog
Oct 17, 2005 04:23 PM
Bill Lehman
Jul 22, 2004 10:49 AM
Daren
15
Sep 5, 2003 02:38 PM
