Ring & Pinions
Old Aug 16, 2009 | 11:05 AM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
Ring & Pinions
I have a Dana 60/70u axle combo with 3.55 gears. Can 4.10 ring and pinion's from the same 60/70u be swapped in? Or do I also need to swap the diff carriers?
Old Aug 16, 2009 | 11:12 AM
dozer12216's Avatar
It is my understnding the cases have different offsets. I know on some years the complete diff assy isdifferent bacause the hole for speed sensor is located in different position.
Old Aug 17, 2009 | 11:32 AM
JPR Ram's Avatar
Thanks dozer.
Any other input or knowledge either way?
Old Aug 17, 2009 | 01:20 PM
Fishin2Deep4U's Avatar
I don't think thy are making thick gear sets for 4.10s for our trucks. A spacer could be used, but I have destroyed more than one over he years in gassers, so I would say that's not a good option.
Most likely a carrier change will be required.
Dave
Old Aug 19, 2009 | 07:27 AM
CTD NUT's Avatar
YES, you can swap to 4.10's WITHOUT changing carriers. The carrier break for both D60's and 70's is beyond the 4.10 mark. 4.56 and up requires a carrier change. 3.55, 3.73 and 4.10 share the same carrier.
Old Aug 19, 2009 | 11:31 PM
JPR Ram's Avatar
Thanks CTD NUT. I was getting a little worried.....Mostly because I already bought some 4.10's from another truck.
hllbllyhellion
Aug 12, 2010 01:48 PM
98.5POS
37
Jan 26, 2007 08:26 AM
HaulinBut
May 12, 2006 03:06 PM
midwestdually
Jan 7, 2006 03:15 PM
StrokeThis2500
Dec 31, 2005 05:19 PM
