ring pinion swap
Old Jul 28, 2008 | 11:38 PM
gotslicks's Avatar
ring pinion swap
say i have 2 identical 2500 rams srw 4x4 2001 both lsd
one with 3.55s and the other with 4.10
i wanna swap gears between trucks.......3.55 into the 4.10 truck and the 4.10s into the 3.55 truck
what is the minium amount of parts i need to order to make this swap happen?
shims? crush sleeves? bearings?
Old Jul 28, 2008 | 11:47 PM
Diesel Doc's Avatar
just swap the axles. it will be easier and cheaper. But if you really want to go thru the trouble yes you will need install kits and alot of time. Changing used gears has to be done perfectly or they will whine.
Old Jul 29, 2008 | 12:53 AM
Desertrider33's Avatar
I agree, I would swap the whole axle assemblies instead of changing gears.
Old Jul 29, 2008 | 01:41 AM
67HotRod's Avatar
I learned the hard way on another truck, change the whole axle!
Old Jul 29, 2008 | 08:46 AM
dozer12216's Avatar
The vote is in on your hypophetical switch, based on your parameters. It always seems as if something is not quite the same in my endeavors.
Old Jul 29, 2008 | 11:32 AM
need12v's Avatar
The way to do it with the minimum parts is to swap complete axles. That will also be the least amount of work. However, Ring and pinions are not as hard to set up as many make them out to be.
Old Jul 29, 2008 | 12:53 PM
PaulDaisy's Avatar
A little bit OT but: if leaving the ring and pinion, but replacing the differentials to say ARBs, do I still need to re-adjust the gear meshing, backlash and all this nice fine tuning stuff?
Old Jul 29, 2008 | 01:24 PM
Stormin_Norman's Avatar
Yes, if your lucky the pinion depth should be close, but you still need to backlash.
Old Jul 29, 2008 | 10:12 PM
dozer12216's Avatar
Backlash and diff preload are necessary when replacing diff in this hypophetic repair. Still a lot of work IMO.
dodge35000
Sep 14, 2008 01:40 PM
Texaschevelle
Oct 7, 2007 10:08 AM
flightmedic992
Dec 24, 2006 12:06 PM
HaulinBut
May 12, 2006 03:06 PM
pwabbott
54
Dec 5, 2002 08:26 PM
