Recommendations for Instruments
Old Oct 11, 2008 | 05:56 PM
Old & Injecting's Avatar
So it is time after LP and IP failure and replacement to get serious about an instrument package. At least LP pressure plus exhaust gas temperature and boost pressure, I think. LP pressure should be an electronic sensor so no fuel line is run into the cab.
What are the recommendations out there for products and paramaters measured? Value? Poor product performance? Good product performance? Ease of installation? etc.
FYI: After the LP and IP replacement, I did a 365 mile trip with a light load at elevations above 7000 feet and kept the speed less than 60 miles per hour .... 21.8 miles per gallon calculated, and 22 mpg on the console. The engine noise level is noticably lower.
Old Oct 12, 2008 | 12:35 PM
mopar-or-no-car's Avatar
I got mine at dieselmanor.com I got the isspro gauges and it was a very well put together kit with everything needed and excellent instructions.
Old Oct 12, 2008 | 12:55 PM
Zeus1987's Avatar
+1 on the dieselmanor gauge package. did mine late one night over a couple of beers and got it done in about 3 hrs.
Old Oct 12, 2008 | 01:03 PM
wurkenman's Avatar
There is also the Quadzilla commander that is digital and with a pillar mount makes a nice clean install.
Old Oct 12, 2008 | 01:09 PM
Mo,
Which boost pressure gauge range did you get? 0-35 psi for running a stock set up, I assume.
Old Oct 13, 2008 | 03:34 PM
I got the 0-60 psi gauge, The 0-35 would be fine if completly stock but if you plan on any mods in the future you might as well get a 0-60 in my opinion. You can get 30 psi out of a stock turbo with any box that does boost fooling and a boost elbow.
Old Oct 13, 2008 | 03:36 PM
P.J's Avatar
P.J
I 3rd. Diesel Manor, bought two complete sets there, David will take care of you.
Don't sweat running fuel into the cab, done it for many, many miles and years with no issues, me and hundreds of others.
Old Oct 13, 2008 | 04:22 PM
Also the mechanical fuel pressure gauge that comes in there kit comes with an isolator, which keeps the diesel outside of the cab and you fill the part that goes inside with antifreeze. Most people on here say not to bother with the isolator becousze its nothing but a pain in the butt. I used it on mine becouse it came with the kit and haven't had any problems.
Old Oct 13, 2008 | 05:02 PM
P.J's Avatar
P.J
You can choose to delete the isolator, he'll back the price out of the kit.
manureman
Jul 9, 2009 08:52 PM
tim0
Oct 2, 2007 07:01 PM
JimmieD
Aug 9, 2007 11:53 PM
User Name:
Jun 9, 2007 02:15 PM
