No Headlights, Brakelights, instruments, or radio!
Old Jul 8, 2009 | 08:51 PM
manureman's Avatar
This is on a 96 12V 5speed. Just got done fixing the 5th gear nut, unhooked the batteries when I had to tack weld the nut onto the main shaft. Put the leads back on the batteries and 'click'. Cleaned the battery cables and terminals, and put them on again, 'click' again, tried one more time then a small arc flash on the driver's side battery. Now I can get it to start, but the headlights and tail lights don't work, gauges don't work, except for oil pressure, radio doesn't work. I checked all the fuses on the side of the dash, and the large ones under the hood. Something smelled kind of warm when this was happening, but can't find anything wrong. Any idea what to check next?
Thanks
Mike
Old Jul 9, 2009 | 06:25 PM
BigIron70's Avatar
Cummins Guru
Check fusible link wires might have burnt out. If you can pull wire and it streches like a rubber band it is burnt out.
Old Jul 9, 2009 | 08:52 PM
manureman's Avatar
Checked fuseable links, all were good. Thinking mayne it's the fuse for the battery?
Old & Injecting
Oct 13, 2008 05:02 PM
banzaitoyota
Feb 21, 2008 06:22 PM
tim0
Oct 2, 2007 07:01 PM
JimmieD
Aug 9, 2007 11:53 PM
User Name:
Jun 9, 2007 02:15 PM
