Rear leaf spring center bolt?
Old Nov 30, 2004 | 10:11 AM
jdeereboy's Avatar
Question Rear leaf spring center bolt?
I need to replace a broken leaf spring bolt and the dealer says it is not a service part. I am sure I can make a bolt, but am interested in seeing if anyone else has tried to get one from the dealer.
This is the bolt that goes through the stack of leaf springs and the head of the bolt is used to center the stack on the lift block.
Thanks
Old Nov 30, 2004 | 10:30 AM
HOHN's Avatar
I'd contact KORE suspension or Keldermann as they are helpful with even the little things..
Justin
Old Nov 30, 2004 | 12:23 PM
BigBlue's Avatar
It's called a tie bolt. I had to replace mine cause I installed my add-a-leaf in wrong and it snapped it in half. All it is is a bolt about 6-8" long, 3/8" or so in diameter, with a round head on it that's about 1/2" or so in diameter and 1/4-3/8" thick. Skyjacker said you could get them from o'reilly's.
Old Nov 30, 2004 | 04:01 PM
Most cities have several spring shops, check your local yellow pages.
wise_cummins
Oct 28, 2013 09:55 PM
GFB
May 8, 2008 01:49 AM
Smkndzl
23
Jan 1, 2008 05:05 PM
Sinbadd
May 19, 2007 01:51 PM
broncobilly
Apr 25, 2007 09:08 PM
