Dodge leaf spring U-bolt ?
Old May 17, 2007 | 04:49 PM
Sinbadd's Avatar
I got a Skyjacker lift for my 2003 DRW 3500 with 4" diameter axle tubes. I need longer U-bolts for the rear leaf springs. The original U-bolts I pulled off are 1/2 X 11 I need something at least 1" longer. I went to the local parts stores and nobody has a 1/2 X 4 X 12 U-bolt. I called up Skyjacker and the cutomer rep said that all the Dodge trucks that they did had 5/8 u-bolts. I did not realize it would be this hard to source correct size U-bolts. Can anyone that has a truck with the HD axle with 4" axle tubes let me know the size of their factory U-bolts? I would like to know if I have the only Dodge truck with 1/2" bolts or are the parts guys not up to date. Does anyone know of a source I can get the correct size U-bolts from over the internet? Thanks
Old May 17, 2007 | 05:07 PM
cquestad's Avatar
Any local machine shop can make you a set...
Old May 17, 2007 | 05:08 PM
pevaguy's Avatar
If there is a heavy duty duty (as in for tractor trailers) parts store in your area, try them. They should be able to get them for you if they aren't set up to make them there.
Old May 17, 2007 | 05:13 PM
Rob C's Avatar
check with the local 4x4 shops and see if they have any, or if they have a place they go to to get them made.
Old May 17, 2007 | 10:23 PM
nriver's Avatar
mine are the same
1/2 fine thread
4" ID
~13" long
those are the dimensions of the new ones I need to put on the truck. Came with my new springs.
think you need to specify that you have the 11.5 AAM rear end. they are prob thinking you have a lighter duty truck
Old May 18, 2007 | 11:59 PM
Sinbadd's Avatar
Went to all the shops around here, heavy equipment, auto (napa etc) no one has the right size. No one around here can make any that I would use for this application. Thanks for responding, at least I know I was right about the size. I did tell the guy at Skyjacker it was for the HD axle W/4" tubes and he said that they only sell 5/8 X 4 X 12 for this kit. I will probably order these and file out the holes in the plate to take the 5/8 U-bolt.
Old May 19, 2007 | 01:03 AM
danshsss's Avatar
Where do you live?
Old May 19, 2007 | 02:55 AM
ataboy9026's Avatar
I got mine from Fabtech. And they are bigger than 1/2". I am pretty sure they are 5/8" diameter but they may have been 9/16". But I do know for sure they are larger than 1/2".It has been a year and I don't remember right now but I will measure if you need to knoe for sure.
Old May 19, 2007 | 09:01 AM
nriver's Avatar
you might try sean lorenz, http://www.lorenzindustries.com/
that is where mine came from, he may be able to help you out.
Old May 19, 2007 | 09:14 AM
Sinbadd's Avatar
Thanks guys, I'll try those places. The link for lorenz isn't giving me a suspension place but I'll Google it. I live about 6000 miles west of California on a little piece of the USA called Guam, which is why things are a little harder to source for me. I appreciate your help
Old May 19, 2007 | 09:38 AM
nriver's Avatar
my bad, fixed
Old May 19, 2007 | 11:49 AM
ataboy9026's Avatar
I just checked and mine are for sure 5/8" diameter and a 3.5" axle tube. But my truck is a 2500, not sure if that makes a diff as I think they use the same AAM axles for 3500, unless it is a dually 3500, that may be a 4". I guess check to be sure. Good luck.
Old May 19, 2007 | 01:51 PM
CrazyCooter's Avatar
Mine are 1/2" too. I just planned to use larger bolts. Seems too small for a truck of this size.
97catintenn
May 28, 2010 08:29 PM
GFB
May 8, 2008 01:49 AM
Joe T
16
Jun 12, 2007 12:11 AM
broncobilly
Apr 25, 2007 09:08 PM
jdeereboy
Nov 30, 2004 04:01 PM
