question
Old May 18, 2007 | 07:48 PM
white06's Avatar
question
ok so i put the smarty on and it seems like the edge has more power than the smarty . it stacks pretty hard and leaves good but doesn't feel like it has the mid range and upper rpm power like the edge. i have ran it on bolth 3 and 5 . any help ?
Old May 18, 2007 | 09:01 PM
RamWheelsBy4's Avatar
Take the Juice/Attitude completely off and see what you think of the Smarty. They do not seem to be a very good stack.
Old May 18, 2007 | 09:06 PM
white06's Avatar
the juced is on stock just using it for the gauges right now . is that still a problem ?
Old May 18, 2007 | 09:12 PM
Well that should not be a problem, I only tried that combo for a day. Found only one setting combo that would perform any better than stock. A few have stated that the combo just does not make any more power than without the smarty.
I can tell you for a fact that on mine the current Smarty with moderate torque management program by itself is more power than the HOT Juice/Attitude and EZ stacked was. What Smarty version/TM are you using??
Old May 18, 2007 | 09:15 PM
white06's Avatar
i was running 3 but switched to 5 the other day . but even with the juce set on the same settings as i would have the smarty on , juced feels stronger .
Old May 19, 2007 | 02:07 PM
white06's Avatar
any help ?
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
