question
Old Apr 22, 2010 | 10:57 PM
zc4life's Avatar
question
why would someone bypass the stock fuel filter? why would you run a direct line from the line pump to the injection pump?
Old Apr 22, 2010 | 11:19 PM
rebal's Avatar
did they install a fass or air dog under the bed with its own filters?
Old Apr 23, 2010 | 06:39 PM
zc4life's Avatar
looks like a fass. i replaced the filter and i still have a problem. still getting the TPS code and it was replaced. it will idile all day, just as soon as i hit the gas pedal it wont react to me pressing on the pedal.. it hesitates... what the?????/
Old Apr 25, 2010 | 09:32 AM
DodgeRamdiese01's Avatar
problem may lie in the APPS unit, not the fuel pump/filter you can do a reset (unhook the batteries for like 1/2 an hour, rehook them and turn the key in the on position, slowly depress the pedal and slowly let up on it) and there are some fixes by adding a new ground did it on mine and it works but my truck just surged not quite like your symptoms
Old Apr 25, 2010 | 09:49 AM
rebal's Avatar
if its the apps, Timbo on hear has a good cheap upgrade
Old Apr 29, 2010 | 03:35 PM
zc4life's Avatar
Is it possible that the relay is bad?
I will try this tonight when I get home, thanks fellas.
Old Apr 29, 2010 | 04:14 PM
Copenhagenjunkie's Avatar
Checked for codes? Sounds like the apps. Search apps recalibration to get you by until you get one from timbo, if that's the problem.
Old Apr 29, 2010 | 05:16 PM
zc4life's Avatar
reset apps, no luck, checked in line relay from Fass unit. no luck. code i get are p0121,0122,1475,1693. is the apps/tps the same? Some codes say voltage too high and some say voltage too low???? any suggestion would be apreciated. truck has been down for more then 2 weeks.
Old Apr 29, 2010 | 05:38 PM
dkenny's Avatar
have you cleaned the grounds??
just a guess, but many problems are ground related..I know I've had some too.
start at the batteries..then the ones that connect the batteries to the motor and the body..
-dkenny
Old Apr 29, 2010 | 07:55 PM
Apps/tps are the same thing. Didn't read that you had installed a new apps until now. I still wouldn't hesitate to use the old apps and try https://www.dieseltruckresource.com/...n&onlynewfaq=1
and cleaning the ground is also a good suggestion.
mkeanglorldo56
Nov 4, 2007 12:34 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
