Proper probing for APPS adjustment
Old Sep 6, 2007 | 09:28 AM
Meat Man's Avatar
I read the FAQ for adjusting the APPS. It says use the proper "back probing" attachment for the mulitmeter. Does anyone have a picture or explanation of this attachment?
Thanks,
Nathan
Old Sep 8, 2007 | 05:05 AM
5string2's Avatar
NAPA ordered one for me. They're labeled "automotive back probe pin adapters." (Fluke brand) A set of 8 was $40 (You only need one). It's got a very thin pin on one end that fits into the connector (at hole labeled 23 on mine). The other end is designed for insertion of a 4mm test lead. I just stuck my thinner lead in that end and it worked (it just needs a good contact). The APPS adj. didn't help me. Check your codes at AutoZone. Also, I stripped a screw head. It would help a lot to get someone to hold the apps bracket while you loosen the screws. Eric.
mfinley
Mar 16, 2009 09:50 AM
Mopar Kid
Apr 5, 2007 03:56 PM
Ocmechanx
Feb 15, 2007 08:44 PM
Diesel-Dan
16
Feb 13, 2007 08:15 AM
bert47
Jun 26, 2004 11:17 PM
