Priming issue
Old Dec 27, 2008 | 05:23 PM
MoNStrRIg's Avatar
Priming issue
Ok I cracked the lines like everyone indicated, but it seems as tho the LP is not puling any fuel, I would think that there is a pump inside the fuel tank that draws it to the LP, is there a solenoid or relay for this?
Old Dec 27, 2008 | 05:33 PM
Erik@LCD's Avatar
which rig? on the 05, there is an in-tank pump, but they fail frequently also. On the 99, there is NO in tank pump, so a failing lift pump would do what you are saying. Get a fuel pressure gauge on there and see whats happening. If the LP is dead (or below 5-7psi) then chances are that your IP has been damaged and will fail soon. Replace as a combo (consider the FASS DDRP) and get a gauge or at least a low pressure warning light on there.
Txbigfoot
Sep 6, 2013 09:45 AM
White00
May 29, 2004 03:01 PM
JARHEAD
Apr 1, 2003 11:07 PM
Guy
Nov 21, 2002 12:09 PM
