Power steering gear box.
Is that what its called?
Mine has alot of slack in it. So I adjusted most of it out, and it eventually came back (15,000 miles or so).
I went to adjust it some more, and theres no more adjustment left. The rest of the front end is tight.
Wheres the best place to get a good deal on one? Should I look for a good used one? (only keeping this truck a few more months).
What did you adjust ? the over center adjustment or the bearing pre-load?? just doing the overcenter adjustment will not take all the slack out of the box. search this site there is a good how to complete with pictures on how to properly adjust the box (not saying you didn't....but I've never seen a box that ran outta adjustment)
Also make sure the box is tight to the frame.
A buddy came by the other day telling me his 2001 2500 4X4 gasser was wandering all over the road and tons of play in the steering.
I climbed under the truck with him turning the wheel.
Found the box moving 1/4 inch side to side.
Tightened the bolts up and all is good now.
Good luck
Good luck
dont buy a reman one I have gone threw about 5 already I finally went to the junk yard and pulled one out of a truck and had it rebuilt,the remans are just painted and new seals thats about it I dont remember what it cost to rebuild I traded some work for it
505diesel
Mar 27, 2006 05:11 AM
unioncreek
Jun 29, 2005 02:00 PM
