power steering
Old Nov 20, 2004 | 08:39 PM
Holycack's Avatar
power steering
Now that it is getting cold way up north, I have a question regarding a loud power steering noise. It sounds somewhat like an old ford except louder. I have had two hydro boosters replaced the last one within the last 1000Km, both times before failure it made this noise. I dont know if its cold related or my hydro booster going out again. Does anybody else who is lucky enough to live in an ice age have this same issue?
Old Nov 20, 2004 | 10:33 PM
KATOOM's Avatar
Have you tried synthetic power steering fluid?
Old Nov 20, 2004 | 10:44 PM
BIGBADBOB's Avatar
Yes change it to synthetic, had to do mine last year at minus 20c
as it was growling. Funny thing is dealer said they had never heard of this. "Bring it in $$$$" was their answer.
Old Nov 21, 2004 | 08:35 PM
Holycack's Avatar
Thanks guys I will give it a try!!
Old Nov 22, 2004 | 09:34 AM
RowJ's Avatar
Valvoline is the only Synthetic PS fluid I know of...could not find it anywhere around here. I used Amsoils Synthetic ATF and it works great. I know Dodge advises not to use ATF in power steering because of brake assist system, but I watched it closely for the first year and had no problems, probably because it is a full synthetic. For all other makes of vehicles, PS fluid is ATF.
RJ
Old Nov 22, 2004 | 11:35 AM
amartinson's Avatar
Royal Purple also makes a fully synthetic power steering fluid.
Old Nov 22, 2004 | 02:38 PM
RowJ's Avatar
Have always suspected Royal Purples Synthetic PS Fluid (Max EZ)is the identical product to their Max ATF. Would not be uncommon for a company to bottle one product under two different Labels (applications).
The Technical Data on these two products are identical...Boiling Range, Pour Points, Flash Points, Autoignition Temps, Specific Gravity, PH's, Vapor Pressures, Etc. Also Components (on MSDS sheets) read identically for the two products.
For that matter, Valvolines Synthetic PS Fluid may be same as their Synthetic ATF.
Old Nov 22, 2004 | 03:41 PM
TPilaske's Avatar
I put Royal Purple PS fluid in my truck a couple months after I got it. No loud whining in the winter and no other problems...
Tony
Old Nov 22, 2004 | 03:54 PM
amartinson's Avatar
I hadn't thought of that, but I bet you are right.
Old Nov 24, 2004 | 08:18 PM
nohemi's Avatar
i changed my ps fluid over to red line synthetic. it steered easier and had less growl.i also run redline mtl in the tranny(nv5600)
tony99
Apr 9, 2014 08:25 AM
Dean Snow
Nov 14, 2007 04:36 PM
DodgeCowboy
Aug 28, 2006 08:57 PM
RAK GUY
Apr 5, 2003 10:28 PM
Garz
Nov 17, 2002 02:02 PM
