Possible causes of injector leak....
Old Apr 19, 2010 | 05:45 PM
sheriffav8r's Avatar
So after putting my head back together I had a leak towards the rear of the head. I just put in new washers on the POS banjo fitting on the back of the head and pinpointed the leak to the #6 injector leaking at the high pressure line fitting. I tried taking the line off and lubing it and reinserting it but it still leaks. My thoughts are that I need to take the cross tube out and check the o-ring on that and then reinsert it and torque down the fitting nut. Does that sound right? Anywhere else it could be leaking besides there?
Old Apr 19, 2010 | 06:52 PM
graphitecumnz's Avatar
Good start, also check the tip of the connector tube, they tend to get nicked if you're not careful when removing and installing injectors.
Old Apr 19, 2010 | 08:33 PM
I've got the metal connector tubes, can I clean those with something? Fine steel wool? I think the mechanic actually pulled the injectors out before taking out the connector tubes but they looked good to me. I'll swap the #1 and #6 connector tubes and see if it is the nut fitting or the connector tube....
dieselnewbie
Jul 29, 2010 12:54 PM
crewcabxlt
May 13, 2009 08:59 PM
northernwheeler
Nov 5, 2008 07:23 PM
LanceD
Mar 27, 2007 01:38 PM
artieb
Dec 13, 2006 04:28 PM
